aussieflash
- Feb 5, 2011
- 1,004
Gday all,
My first post ever.Was going to be a help question 2 weeks ago,though after reading many old posts on trim switch problems i decided to bite the bullet and started to pull the box apart to find the problem....so many parts...so many tests..resistance,continuity,volts,test solenoid,test pump motor.all checked out...must be the trim switch.Had to pull the handle off then pull it to bits to get to the switch.The switch was encased in a rubber protector and hard plastic case which unclipped to reveal the guts...BINGO dirty black points.Cleaned with dremel tool & wire brush bit.Put switch back together (not easy)Ran to boat.Works perfect.I hope this helps someone with similar problem.Now got to try and put box back together.Try and post pictures tomorrow.Bed time 1.30 am.
