tothehouse34
- Apr 23, 2010
- 5
I have my 1980 140 on a 1991 stratos. For the past year everything worked perfectly, trim up and trim down. Started to go fishing a month ago and went to make sure it would trim up and down... it would. The motor is running. The cylinders are going in and out. However, seems like it is not holding enough pressure to lift the motor. It was leaking milky fluid out of the manual release valve so I took the entire assembly off and replaced the oring, didnt leak anymore, but still will not go up and down. I can trim the motor all the way down and the cylinders go almost all the way in, then let off of the switch and they slowly creep out... and after putting fluid in it 5 or 6 times and it will not hold anymore. I cant see any fluid leaking anywhere... does anyone have an suggestions for me?
Thanks in advance!
Thanks in advance!
