Holster100
- Feb 5, 2011
- 11
Hi,
Have a problem where when it is idling sometimes it will stall and then fuel drips from the bottom throttle shaft. It is also smoking a terrible amount sometimes chokes you when trying to adjust carbys.
Has fresh fuel and correct ratio of oil. I have also adjusted carby mixture etc.
I have to use the warm up lever and choke to get it fired up again.
I have checked the timing, rebuilt carbs with new needle seats, new plugs, and fuel pump.
I have compreesion of 120-125psi and all cylinders. Powerhead had been rebuilt in 2002.
Any ideas?
Thanks
Any ideas?
Thanks
