I am trying to get this old boy running again. It used to turn over, but slowly (not nearly enough to start). After verifying I was getting 12 volts at both the solenoid input and from the key switch, I decided to replace the solenoid. Now, I get nothing (but I will recheck in the next few days)- ie- no noise, no action etc. Anyway, was thinking maybe something is wrong with the ground from the solenoid. According to the Seloc wiring diagram, this wire goes from the solenoid to a "safety switch". There is no other wire going to the switch (according to the diagram). What does the safety switch do, and can I ground directly to the block instead? Thanks in advance!
