My Johnson 175 is very smokey and has strong gas odor and some visible gas/oil mix dripping out of the exhaust by the pee stream when idling. When powering up, the engine bogs like it is flooded. So, I back off and power up another time or two and then it surges and takes off. Once it takes off, it runs absolutely great in the mid range and on the top end.
The mechanic said the idle jets are probably too rich and to dial them one to one and half turns clockwise, but after looking at similar posts I think I may have a float sticking, as well. Any help on how to resolve or investigate this would be great! If it is a stuck float, would checking the color of the plugs be a good place to start to help narrow down which carb/s are sticking??
Thanks in advance!! Mike
