A buddy and I bought a small 1972 Starcraft last year, and we're thinking about upgrading the motor in the future. The transom works fine as-is for our 9.8, but I don't think it's safe for a larger engine (center is solid but edges are completely rotten). I've read a bunch of other threads that have extremely similar topics to this, but I just would like some step-by-step instructions and feedback on my ideas to make sure I'm not gonna screw this up. This is our first boat and we figured this is a good way to learn about this sort of thing for the future. I posted some pictures of the starboard side, so hopefully they will help. My plan would be as follows...
1) remove outboard
2) remove corner caps (picture #1 with four rivets, just cut them off?)
3) remove long aluminum transom top strip (picture #2 and 3 with some sort of through-wood aluminum nails, cut them off also?)
4) remove four screws (picture #4)
5) under splashwell, remove all through-wood screws and nuts and bolts (picture #5 and 6)
6) remove transom wood if possible (probably will not come out in one piece)
7) create shape of transom out of cardboard
8) cut two sheets of marine plywood to shape, gorilla glue together, and drill holes for splashwell
9) make sure it fits and epoxy (what kind of epoxy is best, how many coats, etc?)
10) put transom in, work backwards from steps 5-1 (how should I reattach strip and corner caps that were removed in steps 2-3? what fittings would i need to do so?)
Thanks for your help, and let me know if there are any easy ways to do any of the above steps, as I'm sure we'll figure out the hardest way to get them done. If there are any steps that I'm forgetting or special tools I need to get this done, please let me know. I'll post pictures along the way.
http://www.flickr.com/photos/59015837@N05/?saved=1
1) remove outboard
