I just wanted to post a thread so that maybe the next guy doesn't have to learn things the hard way, like I did.
For starters, my 2002 Suzuki DF50 (which ran fine for years) just wouldn't crank. I didn't get any error lamps or beeps. Long story short, the threaded portion of the neutral safety switch had broken, so the ECU thought that the engine was in gear all the time, preventing the starter from being engaged.
Instead of replacing the neutral safety switch, I thought I would just 'fool' it into thinking it was in neutral by removing the switch and just jumping the two terminals in the connector. While that allowed me to start the engine, I had a new problem.
With the ECU thinking the engine was in neutral, it wouldn't let the RPM's rise over 3,000.
Again, I hope that anyone else with either of these two conditions finds this thread and saves some troubleshooting time.
By the way, replacing the neutral safety switch is a little tricky. You don't have a lot of room to work. But the switch is cheap.
