I recently got a Johnson 28 SPL believe it to be a 1988 or 1989 model. It will go into reverse and neutral fine but FWD I have to push the shifter all the way fwd and push down on the shifter near the motor to get it into gear and then it keeps popping back out until I eventually get it to stay in. Things I have tried is adjusting the shift linkage with little success and adjusting the shift cable. (now I don't know if the shift cable is adjustable at both ends?) I just adjusted the cable near the motor. I don't want to keep grinding the gears as I know that can't be good for them... any ideas are appreciated
