bonzoscott
- Jul 26, 2008
- 745
I wanted to see what you folks think. I have a long shaft 15hp on a 15" transom. When I apply full throttle, I can actually see and feel the transom bow. I have seen posts recommending a shim, but it seems the higher I raise the motor, the more leverage it will have over the transom and bow even more. I thought about making a new transom with more height, maybe not the full five inches, but in effect that would be the same as a shim. I don't like the idea of shims in fear that the motor will pull itself off having so little area to clamp to. I'd really like to utilize the motors full power/speed to cover more fishing. The motor seems to be reaching full RPM by sound (it roars). It is a standard 10X9 prop and runs well, but doesn't seem to move much faster above plane. The boat is a 14 ft aluminum at about 350 lbs without gear. I was just looking for your thoughts or experiences. Thanks in advance.
