This is a '96 model. There is nothing wrong with the carburetors yet it won't go much above idle. An '86 manual says to check the timing at about 19 degrees at full throttle in the water. At idle the chalk mark is about 1 to 1 1/2 inches off the mark if that proves anything. Can the timing be checked at idle?
An underpowered battery was used at first and I'm wondering if a damaged flywheel key could have occured and this might be the problem too? Thanks.
