stevo10081984
- Jan 16, 2011
- 40
i have a 1988 johnson 28 spl....just aquired, heard it idle when purchased...sounded smooth...now it runs rough at idle, stalls and wet fouls the plugs...clean plugs and repeat...same thing...fresh gas strong battery...new plugs....where should i start....i have 2 identical motors, only this 1 is giving trouble any suggestions would be apreciated...its 15-20 degrees outside motors are stored in a heated garage but brought outside into the cold to be run in a barrel...also when i get this running is it ok to run at wot throttle while in a barrel, in gear and out...???thanks new to site, was bitten by the bug
