I got the trim pump (1978 prestolite) hooked back up in my boat today and gave it a go. I don't have the solenoids replaced yet and one is bad, so I was just jumping the hot leads from the trim pump motor to the battery to see if it worked correctly. It was very erratic in operation... would run for a second or two, then stop, then would start again and stop and do nothing. The original wire leads from the motor are extremely corroded and green in color with the insulation nearly completely gone. I'm supposing a wire short somewhere in the naked wires, probably where they go into the grommet into the motor housing. The few times the motor did run, it did move one of the trim rams (why not both? because they aren't hooked to the outdrive? no load?), so the pump seems to work fine when the motor will turn it.
I don't want to have to mess with this again for a while, so I either want to replace the pump motor or the whole darn thing. I've seen Don recommend just replacing the whole unit with the newer style with the plastic tank. I see several of these with the plastic tank on ebay. Will they work with my older setup? Am I correct that they mount to the deck rather than the motor like mine? I shouldn't have a problem with that.
I thought I could save the old pump, but guess not. Don't want any problems on the water. Ebay has a couple of the old prestolite pumps like mine, but who knows their condition being that they are so old.
I'm looking at: Mercruiser Trim Pump Late Model
and
Volvo, Mercruiser, OMC Power Trim Pump
What do you guys think? As long as it pumps fluid, it should work, right?
and
