SparkieBoat
- Aug 17, 2009
- 3,643
I just replaced the power pack and the timing base, also put a new regulator on it a couple of months ago. the engine idles at around 1800 RPM in the water..after running for a while I stopped for a few minuets and it started idling perfectly at around 800 RPM. I stopped again in a few minuets and it was idling high again. Engine runs great and I do not think I have a carb issue. Timing base is retarding all the way back and linkage seems correct. did I miss something when I installed timing base maybe?? engine runs great other than this.
