help
mkast
Re: help
If you have power steering, the power steering pump holds the reservoir.
Re: help
Ayuh,... If you have P/S, just look for the pump runnin' off the V-belt, 'n you've found the reservoir...
Don S
Re: help
I don't think that engine ever came with power steering. What kind of a problem are you actually having?
Silvertip
Re: help
IF you have power steering it is pretty hard to miss. Follow the hydraulic lines from the power steering cylinder back to the engine. Or -- look at the front of the engine. It will be the device with the cap that says POWER STEERING FLUID and with a pulley driven by the V-belt. Pretty much like your car so you might want to drag out the owners manual for it.
