'76 Merc 1150 - Carb coupling adjustments
jaggedscars
Hello everyone. I had a question in regards to the coupling between the 3 carbs. I removed them by removing the bolts and then pulling apart. I looked in my manual and no where can i find how to set the coupling between the 3 carbs. I assume with everything reassembled and the screw loose on the couple bushing, either lock them in with WOT or at completely closed throttle. If anyone has insight on this, it would be greatly appreciated. For future reference, i wont be messing with the coupling again!:facepalm:
jerryjerry05
Re: '76 Merc 1150 - Carb coupling adjustments
Go to the Force section.One of the top 2 stickeys has a LINC@SINC by Frank A.That might be some help.Jerry
