I discovered when I checked the timing that it was firing on the degree numbers at times and then it would fire 180 degrees off at other times.Some times it would be right on and other times it would only fire 180 off. The number two plug fires correctly all the time.Does this sound like the powerpack? The motor idles but boggs when giving it gas. I cleaned the carbs and checked everything else before I found the timing issue.
