johnson 15 idels and runs 3/4 but bogs at wot
bubba3689
Hi guys. I have been reading the forums for a couple weeks and has just been too lazy to register. i have learned so much already. well to the problem. i have a 1985 johnson 15hp. it will start on the first or second pull idle for days, then when i put it in drive it will bog down till i play with the choke and i can find a sweet spot for it to run at about 3/4 throttle. it will go full throttle perfectly then die after about 150 yard of WOT running. if anybody can help me out id really appreciate it. thanks in advance
SparkieBoat
Re: johnson 15 idels and runs 3/4 but bogs at wot
fuel pump or dirty carb is my guess..also could be fuel line sucking air at one of the connections
levi_tsk
Ensign
fuel pump and if i remember correctly the motor you have is got the small square pump and it is a ROYAL PITA to rebuild ....unless someone aready upgraded it
if its the small square pump heres the part number 393088
HighTrim
Could be the pump, could be the carb. Are the fuel lines original? Will pumping the fuel primer bulb keep the motor running smooth? What about if you take a spray bottle with pre mixed fuel and spray it into the throats while underway, will it keep running?
