First do a compression/spark test.Then the fuel system:check the fuel pump and then the carb.
Remove it and use any spray cleaner.Don't use carb soaks.
Ethanol weakens rubber and delaminates the inside of the older hoses.Make sure the gas in the tank is new.New plugs next.Jerry
