1988 60hp evinrude leaks gas
mckbdck
I have a 1988 60hp evinrude vro that leaks gas all down the out board when turned off.
The motor runs fine just leak all that fule. could the gasket between the carbs and block be bad. the vro is still hooked up but ihave been mixing the fule because I dont trust the vro
jtexas
Re: 1988 60hp evinrude leaks gas
Warm starts ok?
Is the fuel line holding pressure?
Been doing that since you got it, or did it just start? What recent maintenance has been done?
Faulty carb mounting gasket usually lets air in, instead of letting fuel out. More likely carb bowl gasket, or fuel lines getting old & stiff.
Could ya be a little more specific about where you see gas? Close inspection of all the fuel lines, carbs, pump & fittings while somebody squeezes the primer bowl should pinpoint the leak.
You should be able to tell whether the VRO is working, by watching the oil level in the reservoir. Double oiling isn't going to do that motor any good in the long run.........
mckbdck
Warm starts ok?
The boat had the carbs rebuilt about 7 years ago. The leak just started this last season, it starts fine when warm. The oil alarm goes off now and then thats why I don't trust the oil pump the tank dosn't seem to change levels,wont to by pass.
The gas looks like it is around the gasket between the block and carb.
5150abf
Dry everything off and pump the bulb a couple times and see if you can find it.
Also change your gas line if you haven't, 23 years is a pretty good service life and make sure to get all the hose under the hood, you wanted to disconnect the VRO anyways.
A gas leak under the cowl can be really bad, I have seen boats launch the cowl a 100' in the air when the gas/air mix gets just right.
jtexas
levi's right, if a carb is leaking, looking for the source is a waste of time -- no matter which gasket it is, a rebuild with new kits is the fix.
there's a thread on carb rebuilding in the "top secret file" at the top of this forum -- you can do it.
