micky d
- Jan 8, 2011
- 10
hi ppl,
i have an 83 pride cheetah and i just put a new motor on it. i was doing some work on it and i tilted it so the bow was up and water started POURING out of the old engine bolt holes, and either side where the bottom 'shell' meets the top shell.. i realise the transom is full of water, but, it is still strong, very strong, if i yank on the motor while in the up position, it doesnt budge the transom at all..
the boat was sitting in a yard for a year or so and had collected about a foot of water in it when i was given it..
it has a large rubber 'band' around the perimeter of the boat, so im guessing i can remove it, separate the top from the bottom and check it out? is this possible or are they usually glassed together as well on the join?? thanks in advance for any help!!
mick
mick
