Re: whats the difference between these 2 part numbers?
If ordering from Mercruiser, the A3 will be sent if you were to order the A1.
While normally this is known to be true, Actually in this case it appears not to be true at this time.
Part number
807166A1 shows no Item Supersession Chain from mercruiser.
But part number
807166A3 Shows these part numbers in the Item Supersession Chain:
Row Class Part Number SS Level Disp Description
807166A3 00 ACT SHUTTER ASY(PAIR)
14348 01 SS WATER SHUTTER
14348A1 01 SS SHUTTER ASY-WATER
4
14348A2 01 SS SHUTTER KIT-WATER
Tailguners engine should require him to use part number 807166
A1.
http://www.mercruiserparts.com/Show...5.png&inbr=2705&bnbr=270&bdesc=EXHAUST+SYSTEM
Mercruiser also has a stand alone part number of 807166
A2, But it has no good picture of what this style shutter looks like that I can find, But it looks like achris remembered the differents.
http://forums.iboats.com/showthread.php?t=426899
