Pretty simple question I hope. So I have a starter problem. Hit the key get the high speed spinning, gear is not popping up and engaging. Friend said sounds like bendix spring? I have been searching with little luck for a bendix spring. I have the repair manual and it more less explains how to clean it when you have this problem after you run a few test. Any detailed fixes would be great. I saw one posting that said to lubricate shaft to fix the problem. Person necer responded back to say if that fixed it. Thanks for any help Jeff Wolf
