Re: Cost for a wetsand ?
Just a thought
If it was a bad paint job that might be a plus for you.
They might not have preped the surface underneath the paint that maybe
why it did not stick
Not sure what type of paint but try some solvents that will not damage the gel coat
Maybe acetone
If you get lucky and the paint can be removed then you might want to wet sand the gel coat that is underneath the paint
Maybe someone here has removed paint from gel coat they might know what solvent will work
take a look at this
Clean the area with the paint that is to be removed first. Prepare a solution of a 5% caustic soda detergent, and 5% citrus degreaser in a large bucket of warm water. Apply the solution to the surface and scrub with a soft-bristled brush. Rinse thoroughly and dry completely
Visit a marine supply store and purchase a marine paint remover. Do not use an ordinary paint remover, or anything that contains methylene chloride. It will damage the gelcoat.
Use a wide paint brush and apply the remover to the paint on the gelcoat surface. Leave the remover on for a while, allowing it to soften the paint. When you can begin to rub off the paint with a rag and a little elbow grease, it is ready.
4
Use a generous supply of clean rags and rub off the paint and remover from the gelcoat. It will take a little work, but it will come off. Add more remover as necessary for difficult spots. Rinse the area thoroughly.
Things You'll Need:
Caustic soda detergent
Citrus de-greaser, both available at janitorial supply stores
Soft bristled brush
Marine specific paint remover, available at marine supply stores
Wide paint brush
Clean rags
Read more: How to Remove Paint From Gelcoat | eHow.com
http://www.ehow.com/how_5246979_remove-paint-gelcoat.html#ixzz1BUc5zktM
http://www.ehow.com/how_5246979_remove-paint-gelcoat.html#ixzz1BUbwI500
