Boat is a Dynasty 190 fish& ski with a OMC 4.3l engine. I am removing the transom assembly so I can rebuild the transom (water is leaking around the assembly, could just be the seal, but I imagine it has rotted the wood). All is going well so far thanks to the Factory service manual, a Clymer's manual and the info found here. Only problem I have is I can not remove the bolt that holds in the shift cable to the pivot housing. The shift cable, red, goes thru the bolt with a brass housing on the inside of the housing. When I turn the bolt, the brass housing on the other side just turns with it. I tried holding the brass assembly with some pliers, but am kind of leery about messing up the brass housing, so did not use vise grips etc.....
any ideas on how to get that bolt out. Cable and sheath is in good shape, so would prefer to keep it and not cut it as I know I am going to be spending a fair amount as is to repair transom, so every penny saved.......
thanks for any info
thanks for any info
