Re: Evinrude 25hp help
Drill two small holes, side by side, lengthwise, through the screw. Then, keep drilling the holes with progressivly larger bits till they reach the threads, and hopefully intersect in the middle. Then the screw will hopefully collapse toward the center and you can remove the pieces. Can be done, takes practice.
