Hi, I have a 2002 Larson 20 foot bowrider. Both of the vertical molding pieces - on starboard and port side - that go from the top of the transom motor mounting surface to the start of the rub rail are cracked and need to be replaced. For some reason, Larson decided to make these out of plastic. I've contacted several dealers and both have said that the molding pieces are NLA from Larson.
I've looked on ebay with no luck. Any advice for finding these or is there anything aftermarket or alternative that can be used instead?
Thanks for any help or suggestions!
