dannieboiz
- Aug 25, 2009
- 111
I did all all the researches for a month then bite the bullet on a typhoon 14x19 4 blade prop from my original 14.5x17 3 blade both are SS. I'm going to be out of town for a few weeks so I can't test this but I'm itching to find out what it's going to be like.
95 Seaswirl striper
5.7L with an OMC Cobra SX 1.66 gear ratio.
WOT = 5k RPM
top speed 45mph +-
cruise at 3500rpm (is that the right cruise RPM?) @ 26mph +-
The boat dry weight is 4600lbs fully loaded I'm thinking 5500 - 6k lbs
ATM I hate how my bow points to the sky when I take off even with my trim tabs.
My goal is to bring my WOT down to around 4600-4800 RPM which I believe is the manufacture recommendation. Going up to a 19p prop would most likely achieve this but the only difference is I'm going from a 3 blade to a 4 blade and a 14.5" to a 14" prop, what would these factor play on my performance?
I hope to maintain a cruise speed of at least 25mph while lowering my cruise RPM down to maybe 3200rpm hopefully this would yield some better fuel economy for me.
95 Seaswirl striper
WOT = 5k RPM
top speed 45mph +-
