The bottle says mix at 2oz per Gallon of Resin. I am going to be mixing 1liter at a time for my deck. 1 liter is right at .26 (about a quarter) gallons, so that means .5oz wax, right? I just wanted to make sure my figuring is correct here.
I was also told that the amount of wax should be about double the amount of mekp I use. Is that about right too? Due to (very) cold temps this week (even with the heater burning), I've been having to use nearly 2.5% mekp to get my stuff to harden correctly. Should I just double that? I want to make sure this last layup on the deck isn't tacky at all.
Thanks! Almost there with the deck. Woohoo!
PS.. is there a problem with the search feature on iboats since the redesign? I search for "wax" under "posts" and searching in "entire post" in the resto forum, and it finds nothing! What? I've had problems searching for other stuff too recently.
