Rainbow Bridge
- Dec 2, 2010
- 14
Hi,
My 79 Bayliner AQ260A (350CI Chevy) Volvo has a leak waaay down in the bottom of the exhaust yoke, (think it's a crack), so i have to pull the engine. It's got 820 hrs, many in salt water, but I've done the heads twice and installed a new oil pan, elelbrock intake, exhaust manifolds, starter, alternator and fuel pump. Also, it checks out at 120PSI compression in all cylinders...so here's the question..do i replace the block? and if so...
1) stay with the quadrajet or go EFI?
2) swap the heads and go short block?
3) Keep the old Prestolite distributor? (which i put electronic ignition in)
Thanks for your input!!
Russ
Russ
