matt85evinrude
- Dec 27, 2010
- 33
hi guys! my motor has compression very good spark and wet plugs. every night after work with a bit of cranking it will start at idle and run untill i turn it off, (but if i try a manually increasing the throttle lever on the side of the carbs to increse revs it will die slowly) any way, after turning it off it wont start again for the rest of the night. any ideas guys?? im so stuck!
