Re: 140 v4 Evinrude Block ..Rebuilding Question
Dont use the Wisecos as they are soft and it takes several heat cycles to harden them up. You will be better off with a cast piston. I recommend using the Promarine,Vertex or Persan pistons. If the pistons dont come drilled you can have machine shop drill them or lower the bridge a tad with your finger and some 120g cloth. I lower the bridge with a porting grinder and 120g flap wheel.
