kfa4303
Banned
- Sep 17, 2010
- 6,094
Hi all. So I really opened up a can of worms trying to re-seal my lower unit myself. I got everything apart fine, but I managed to damage/destroy the bearing housing assembly under the water pump (#377186) while trying to remove its seal, and the seal still hasn't budged
I even bought and used a seal puller. I need to get a replacement, which I have found online for $60 (ouch). I also need to remove the prop shaft seal, but its bearing housing looks pretty rough and gouged up from where PO have changed it in the past. I'm afraid to try and get it out myself for fear of damaging the bearing housing any further. I cannot find a replacement for it so I'm leery of messing with it. Not to mention the clutch dog which is a bit worn, but I think I can do the flip trick to see if it will help. Overall, I guess I'm just wondering when to say "when" on this LU. The motor itself runs like a champ, all the gears are perfect and I've cleaned everything so you can eat off it, so I guess I could part it out, but I'd like to try and get up and running, if at all possible. Plus, I'm afraid if I get and new LU online without being able to see it, I could be right back were I started from. Any advice or wisdom would be greatly appreciated. Thanks to everyone for helping up to this point.
