kwoolard
- Feb 9, 2003
- 420
I have some gunnel or gunwale panels that serve as rod storage on my boat. Access behind the panels is required for wiring maintenance if ever need be. What type of caulking can I use to seal the panel to the floor that would make for a fairly easy removal in the future?
I know not to use 3M 5200/4200 or any caulking that is polyurethane based. I've seen stuff called Life Seal or Life Caulk but it is a polyurethane/silicone blend. I was thinking about 100% white silicone from Lowe's or HD that is exterior and mold/mildew resistant.
What do you guys recommend? The gap is 3/8" wide by 3/8" deep.
Thanks!
Thanks!
