Re: 2002mercury 75 hp...... stator going out??
What other electronics are you talking about. Neither a GPS or a Locator use any significant power. Since you have two batteries, do you have a dual battery switch, isolator, ACR, VSR or any combination of these. If you simply have the two batteries connected permanently in parallel, one of those batteries is probably bad. Disconnect them from each other and run one at a time. That motor should have no trouble keeping two batteries charged unless one of them is connected to a trolling motor and it gets deeply discharged. Remember too, that if that is the case, then making longer runs will likely see the voltage come up the longer you run. Batteries do not charge in a short run back to the dock. As another test, shut the engine off and then measure battery voltage. It may measure 12.6 volts with no load, but the minute you add a load one bad battery in the system will quickly drop the voltage. I happen to have that same engine and can run a locator, radio, and live well pumps (timed) and lights with no hint of the "starting" battery getting weak. Even my 40 HP Evinrude with a 12A alternator had no trouble with the same accessory load.
