Mariner 2008 30hp MLGA EFI OR27****- Stator wiring help
JungleJim42
Hi
My engine is not fitted with a charge regulator/rectifier, so I am looking for a second hand unit.
My problem is this, In the 2002 service manual, the stator wiring diagram shows 2 yellows for the stator output going to the regulator, my 2008 model has 3 yellows coming out from under the flywheel leading to a grey 3 pin connector which the regulator should I believe attach.
Can anyone confirm that the stator on later models have 3 yellow outputs or not??
many thanks
Re: Mariner 2008 30hp MLGA EFI OR27****- Stator wiring help
Ayuh,... I donno, but this'll get ya back to the top...
Laddies
Banned
Where's Rodbolt he would have this answer
JungleJim42
Thanks guys, perhaps Rodbolt is on holiday.
