Re: 1970 Johnson 60 Hp Stuck in reverse
Can you move the shift lever at all? Take the spark plugs out so you can turn the flywheel by hand (clockwise) then try to shake it loose. Check the gear oil level. If you are in a cold climate, it's possible (if there's water in the gear housing) that it's frozen.
