What is safe Oil Pressure for Mercruiser V6 MPI?
Walt Kowalski
Our boat (19' Bowrider) has 42 PSI when hot at cruising speeds
Seems low to me.
Recently had dealer service.
120 hours
Alfa 1 leg
Used in fresh water
Is this normal?
P.S. did a search but nothing that I could find on this forum.
Re: What is safe Oil Pressure for Mercruiser V6 MPI?
Ayuh,... Welcome Aboard,.... What motor,..??
10psi per 1000rpms is acceptable...
ENSIGN
At least you have the smarts to watch your gauges! 40 psi sounds ok
engr1962
I have that same engine and with new oil and filter it runs around 42 PSI alittle above idle.
