Re: Limp Mode 90hp Johnson Ocean pro
you are going tinto SLOW mode, your motor doesnt have the fuel restriction alarm, only the V6 modles of the same name had that feature..
you can run because two things happen....
your temps drops below 207 degrees F AND
you turned the key ioff, then back on...
if BOTH of those things dont happen, then you will be stuck in slow mode, which shouldnt allow you to rev past 2500 rpms
I have a similar motor and experienced that problem
you need to fix the source of your over heat issue!!!!!!!!!!
you if you ahve astrong stream for the tell tale
then you need to check and or just replace your thermostats
they are very easy on that motor...make sure you dont crack the plastic housing untightened and retightening
after tha, you should make sure you dont have a lean condition( which can cause over heating)
check your compression now, that you know you have over heated your motor!
good luck
bob
