I am trying to remove outdrive for bellows and the drive is stuck in neutral. It ran fine last time in water. The controll arm will go into the forward position but not reverse. I can see the cable moving the pivot arm by the transom. It moves about 1 inch. How do I manually move it into drive? I have searched but have not found an answer. Thanks
