I have a problem getting my 2005 90TXRD to start after I replaced water separator\fuel filter and drained\checked engine mounted fuel filter.
I've been told that I have to "reset the fuel rail presure" but don't have the procedure to do that. Owners manual is on order!
Sorry - I should have stated it is a four stroke. I agree the 2-strokes are easier to maintain.
I found that there was no fuel in the line from the fuel separator and was able to get fuel up to the bulb. But I changed to a clean portable tank to remove any fuel line/tank issues, linking the portable tank in on the engine side of the primer bulb.
I got good pressure on the portable tank primer bulb and have a full fuel bowl on the engine but she still doesn't fire up.
I'll continue to look to advice on getting air out of the injector side of the fuel system.
Thanks for the response.
