mikethepike
- Dec 15, 2010
- 42
I use my boat in the winter to access different islands that have ice connected to it so i can ice fish, so :
1st question: When i launched it for the 1st expedition, the water exhaust didnt come out for over 4 minutes at idle. I shut it down and let it cool off for 10 minutes and then started it up again and it started to "pee" after another 3 minutes. Is this normal that the water exhaust didnt start right away , or should i look into replacing the impeller? No problem "peeing" in the spring/ warmer weather at start up
2nd question: When i'm done using it and i leave it a non freezing canal for the winter, do i leave the water pick ups in the water so it doesnt freeze or leave it out? What if i decide to trailer this right after use, do i leave it down and just let it drain or should i run antifreeze thru it?
Thank you in advance, Mike
