runs rough
bullstedman
I have a 18304 a evenrud 1973 she runs rough at lower rpms its like a intermittent engine miss. It has new plugs it doesnt seem to do it after half throttle. could this be a points issue or a coil or is it the champion plugs?
rickryder
Re: runs rough
Might be a carb issue.... How dose it idle? Have you cleaned out the carb?
bullstedman
Re: runs rough
Its seems to idle fine but rough at times it will run perfect and flutter and than smooth again.
rickryder
Re: runs rough
It wouldn't hurt to drop the bowl on the carb and see if there is any dirt in it.....sometimes a bit of crud floating around getting stuck in a passage will give you idle/low rpm roughness... Check if you have a good spark and if you haven't looked at the points that wouldn't hurt either....check all wire connections for corrosion and that they are tight.
kenmyfam
Re: runs rough
Basic health check.
Compression
Spark
Fuel delivery
Spark plug condition
Post results.
If you don't know if the carb's are due for a service then they are due.
steelespike
Re: runs rough
I don't find a 18304 only 302,303.1963.?
Also don't find any 73 18hp.63s have a low speed mixture adjust.
Sounds like a lean sneeze.With it warm in gear Adjust the lowspeed needle toward rich (out)
till it smooths out.
