My '98 Evinrude Ocean Pro 115 has developed a leak in the lower unit. I bought the motor in Sept. and replaced the gear lube then. What came out looked clean and I even checked it several times since I changed it and no problems until two weeks ago.
I took it to a local shop and they pressure tested the l/u, re-filled with fresh Sierra gear lube, said they could not find a leak and charged me ~$120. I asked why I was getting water in the l/u and they said it was most likely a loose vent or drain plug because they said it held pressure for 20 min. They then told me to take it out and run it and let them know if I found water in there again.
Well, yesterday I ran it for about 2 hours and sure enough, I found milky gear oil when I got back home.
The shop did not remove the l/u, they just pressure tested it. What are they missing and why did the pressure test not detect the obvious leak that I have? I see no leaks around the l/u even after it sat for 4 weeks.
BTW, I'm running out of patience with this shop and am considering going elsewhere, but having spent $$ only to find nothing wrong, when I know there is something wrong, really ticks me off.
