Happy new year to all.
the motor is a 125hp mercury year 1994, the tilt - trim unit is a motor pump, one piston unit under the motor.
Last time out on the lake bassfishing was a couple days ago, thats when I noticed that as I tilted the motor up to remove the transom support it went up very slow, I could hear the motor on the tilt unit going strong but the piston was doing a poor job lifting.
Likewise at the end of the day, when I lifted the motor to place the transom support back on I thought it was not going to lift enough, and I noticed that the piston ram or shaft had a white substannce like when water and oil mix. Im pirty sure water is in the system.
Questions, can this be fixed, where can I get the repair kit and literature-instructions.
I tryed the FAQ but with no results, I've checked the webb but cant find related info or even a price on a new unit.
Any help will be greatly appriciated.
