Connecting a teleflex splashwell mount to a 'rude without tilt tube
flamon
I have just finished (sort of...that's why I'm here) installing a splashwell mount with a NFB teleflex steering kit and realised that I should have read the part that says it is designed for splashwells up to 760mm and mine is about 900mm. The cable only just reaches at full extension when the motor is centered. Anybody got any ideas as to how I could lengthen the telescopic arm. Any reasons why I couldn't? (I hope not because I have cut a big hole in the splashwell to install it and really don't feel like going back to the drawing board)
Any advice would be greatly appreciated
flamon
Re: Connecting a teleflex splashwell mount to a 'rude without tilt tube
bump.
don't know if bumping is a done thing around here but I am desperate as this is the last thing to do to finish my restoration.
Thanks in advance
F_R
I suppose something could be fabricated to extend the rod, but I don't know of anything commercially available. There is also the queston of liability, should something go sour.
boobie
I'll go along with FR on this one. I'm not that familiar with your steering system, but couldn't you get a longer steering cable?
jay_merrill
If you are talking about one of these, your fix really isn't all that difficult.
http://www.westmarine.com/1/1/11609--splashwell-mounting-kits-90-straight-splashwell.html
(Sorry iboats, could find an example here at the store)
What you must do, is to build a mounting pad that is as much in thickness, as the distance that you must move the mounting point towards the engine. If you can shape it in a way that it fits into the corner of the splash well, at the intersection of the transom, that would be good.
I would laminate plywood to do this. You can build up the laminations as much as you need to, in order move the Teleflex adapter as far inward needed. Using laminated ply will also allow you to use a hole saw on each piece before gluing them together. This way you will not end up fighting with the saw, trying to drill a hole that is several inches thick.
Cut your pieces of plywood with a bit more height and width than you think you need. When laminating, line the holes that you pre-drilled up exactly and then apply the glue and clamps. Once the piece is cured, you can go back and shape the dimensions as needed. I would make the piece large enough to cover enough of the sidewall on the slashwell, to insure adequate strength.
When you mount the piece, you can either fiberglass in in place, using both the surrounding splashwell and transom for overlap, or you can bolt the piece in. For the fiberglass method, I would coat the side that will be under the mount with resin, place a cut piece of mat on that, coat the inner surface of the pad and then put it in place. In order to insure a tight bond, you can cut a couple of boards to an appropriate length and use them to jam the piece in place, by running them across the splashwell to the other sidewall. Once that step is done (cured in place), you can do the outer glassing.
If you decide to bolt your adapter on, be sure to use a large backing plate (wood is OK, if you use large washers under the nuts). The backing plate needs to be able to fit behing the well and you obviously will need some "wiggle room" to get your hands into the space where it will be located.
All of this will take some time, but if you can't find a steering cable with a longer end piece, you probably don't have a better alternative. I really don't recommend trying to trying to make some sort of home-made extension piece - its just an accident waiting to happen.
PS: One more thought - when you drill the holes in the laminations for the adapter to pass through, make the holes progressively larger, from the outer point to the inner point. This will allow the adapter to move with enough range to allow tilting of the motor. If you don't do this, the ball swivel will be useless, because the tube will have nowhere to go, when trying to move up/down/fore/aft.
flamon
your idea makes sense but I don't think it would work for me. The extension I need to make is probably only 4 inches and I think it is achievable using a stainless steel rod without causing a safety issue. I just need a way to stop it from pivoting where I join it to the telescopic arm.
I will keep thinking of a solution but will keep your idea in mind.
Thanks
F_R
A good machinist could make you an extension that slips over the end of the existing rod, with a bolt through it to keep it from coming off. I figure you need to extend it a minimum of 3", more would be ok because you can adjust the tube outward. But he deserves to be paid and it might cost you a couple hundred bucks.
Really, we all know the solution is to admit screwing up and start over by installing either a transom mount or one of the front mount tube kits that go below the motor. Then the queston becomes, is the cable long enough?
Then there is the hole in the splashwell. Of course, a hole is needed there anyway, so it might not be a problem. If you made a nasty and ragged looking hole, oh well, fiberglass can be fixed.
