how to pull drive shaft on 115 94 mercury lower unit
B billsgills Recruit Joined Dec 26, 2010 Messages 2 Dec 28, 2010 #1 how to pull drive shaft on 115 94 mercury lower unit
Faztbullet Supreme Mariner Joined Mar 2, 2008 Messages 15,616 Dec 28, 2010 #2 Re: mercury ower unit Remove water pump and base,remove carrier and propshaft,remove pinion nut, pull up on shaft and smack side of it9driveshaft) with rubber hammer to jar pinion gear loose.
B billsgills Recruit Joined Dec 26, 2010 Messages 2 Dec 28, 2010 #3 Re: mercury ower unit thanks i'll try that. billsgills
