adamonimac
- Dec 27, 2010
- 3
Hi All,
I've got a 4.5hp johnson seahorse motor that last time it ran stopped making water at the teltale at idle speeds. I'm assuming that the impeller needs replacing. So heres my problem. I've removed the 3 bolts holding the lower unit to the leg, but the lower unit wont move down more than about 4mm. I think that it has something to do with the shift linkage, but I cant see anywhere that looks like a join in the linkage that needs to be undone. Any advice / diagrams etc appreciated ! As far as I can tell its a 1982 model (J5RHCNR)
Thanks
Adam
Thanks
Adam
