Greetings All,
I got a 1988 Chaparral 204 Fisherman WA Cuddy with a 1978 175 HP 'rude for a steal.
The motor runs great (120# all cylinders. lower unit pressure tested-no leaks). The exterior just needs to be cleaned up.
There are no soft spots anywhere. It was someone else's project and they partially painted it (above the waterline). I'll finish the bottom paint myself.
I tore out the plywood walls of the cabin (rotted on the bottom) and the plywood cabinet under the helm.
I am going to replace all the wiring.
My question, right now, is what kind of plywood/wood can I use to replace the walls/cabinet/doors/trim. Would oak plywood properly stained and sealed do the trick? Any other suggestions?
I'll post some pictures soon.
Thanks,
Learn2Dive
Thanks,
Learn2Dive
