Re: Need cooling system troubleshooting tips for yamaha.
If its like my 90tlry 2stroke is easy to replace water impeller. First thing I would look at pull thermo out and check for obstructions. Sometimes rocks and stuff get in there. Also hook the hose up and try to clean it out. Then install new impeller kit. There's bolt under that rubber thingy towards front, one under that metal plate thingy, couple on each side motor. Leave the bolts holding the lower on a few turns pull down to show speedo tube. My unit is two piece shifter shaft so no nut needs to be loose, my speedo line was cut already so it dropped out very easy. Only problem you might find woodroof key needs to be hit with brass pin, harbor freight has these right now $1.77. Grease the new rubber impeller while installing. Cleaning out the motor is good idea, flush port makes this so easy. Also try and run on muffs. What ever you do dont over heat the motor.
