VaGent
- Jul 14, 2008
- 221
I am told the rings need to be replaced in my 1987 Johnson 70 because it will not idle below 1200 rpm in gear. I was told its because of the rings & as I am not an outboard mechanic I really don't know. What I would like to know is what is a "reasonable & fair" price to have this done? I was quoted $1200.00 turn key job but have also been told that is "priced high". Does anyone have any knowledge about what is fair or high on doing a job like this?
I've already had the carbs rebuilt, complete engine tune-up, water pump & lower seals replaced & the engine runs very good above 1200 & doesn't skip a beat. I run it on my pontoon boat that is 24 ft weighing approx. 2300 lbs loaded & with GPS it says I am getting 17 mph @ 3800 rpm. It just won't idle like it is supposed to which I am told is around 900-1000 rpm. Any advice would be appreciated. Thanks
